Export loads from Excel to Robot automatically
Dear Users,
I would like to create load cases in Excel with the actual loads on the different structural objects. I have made an excel which creates such loads and the input is the objects. Now I would like to export these load cases from excel to Robot.
I have read previously the posts (API Extraction of loads into Excel/ Editing load cases in excel) linked below about the possibilities. I saw the importing worked with dumpingloadsforeachobject.xlsm.
I also tried to use the API of RMI_loadcomb_nested_with_subnatures.xlsm made by Rafal.Gaweda. Is it just for adding load cases and combination without load values ? Or it is just my failure, because I have tried to add a simple line load on a bar, but I couldn't make it. Can any of you who had success witht that API to help (tony.ridley or Rafal.Gaweda) ?
And if that API is not for that reason is there any for exporting pre-defined loads into Robot automatically? (I can copy paste of course, but several times after copying some loads changed by mistake after pasting them in.)
Thanks in advance either an API like this or some explanation for RMI_loadcomb_nested_with_subnatures.xlsm would be a great help!
API Extraction of loads into Excel; forums.autodesk.com/t5/robot-structural-analysis/api-extraction-of-loads-into-excel/td-p/6011075
Editing load cases in excel: forums.autodesk.com/t5/robot-structural-analysis/editing-load-cases-in-excel-api/td-p/3320573
