I'm modeling simple supported concrete beam to Footfall analysis. Execution problem 902 is message during modal analysis. I saw the post with same name and my model is in 3D. So could you please give me any instructions.
Regards
Solved by Rafal.Gaweda. Go to Solution.
I checked all posts. My model is linear, modal analysis is linear analysis and all supports are also pinned (there is no nonlinearity through any uplift or similar).
In that table in post - 902: ''negative eigenvalue has been obtained '' -- robot wan't to calculate eigen values in my case. The message appeares earlier.
There is robot file.
Thank you Rafal for fast answer.
Regards
Hi, please somebody can help me with the error Execution Problem 902, I know that is a problem with the Negative eigenvalue has been obtained, but I do not how to fix it.
Regards
Abel
@Anonymous wrote:Hi,
Regards
