Exclude accidential load from service check
Hello!
I'm modelling a rather simple steel structure which is exposed to an accidential loadcase. I have specified the specific load as such and performed an automatic load combination.
For this structure, I have very strict deflection requirements, but these doesn't apply to the accidential load case. For some reason though robot includes this load case for final deflections (as well as the combined ACC load) in the Elements Steel Design Check.
Is there a way to exclude these load cases here without dealing with two separate models?
I hope I made myself clear enough, I attached some figures to illustrate!
Regards!
Artur.Kosakowski
Autodesk Support
Autodesk Support
SLS check is done for the list of combinations entered in the corresponding filed of the load case selection included for steel design. It should be enough to exclude the accidental ones from this list.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Yes ofc, I knew that when you say it! 🙂
I must blame just returning from a vacation! 😄
Thank you for a quick reply!
