Eurocode dans Expert
Bonjour, j'ai des questions pour ROBOT EXPERT, j'ai bien choisi la norme Eurocode dans les préférences comme la figure ci dessous.
Après, je constate que ce logiciel garde encore le terme du BAEL, tels que "fc28", "fe", qui ne sont plus utilisés dans les Eurocodes. C'est un peu bizarre, non?
Une autre question, est ce que le menu "Condition de fissuration" correspond aux classes d'explosition de Eurocode 2? Si oui, pourquoi il y a 6 classes dans Eurocodes, mais il y a que 5 classes dans EXPERT?
Merci d'avance
Yan
Artur.Kosakowski
Autodesk Support
Autodesk Support
This calculator supports only the old version of EC2.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
So, the word "ENV" means “the experimental standard”, right? Is it possible to update EXPERT with final version of Eurocodes  (the most recent version)?
By the way, can you assure me that your software “Autodesk Robot Structural Analysis Professional 2013” uses the final version of Eurocodes  (the most recent version)? It is a request of my customer! Thank you for your understanding!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Correct.
No, this is not possible.
 You can check the version of the code in Job Preferences
Artur Kosakowski
