Error while creating robot registry key
Hi
I know that there is a similar post in the forum but the replies are mostly not in English and I couldn't understand how it got sorted, so apologies if repeated.
Our company uses Robot through a networking licensing system and it's common for many users to have different versions installed at the same time.
We've realised that every time you open a version that is not the latest, you get a "Error while creating robot registry key." message.
My questions are:
1) Does this error/warning affect the use of the software in any way?
2) Can it be fixed?
Filipe
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check this AKN article
ROBOT - registering, reregistering, running two or more different RSA versions on the same computer
Artur Kosakowski
Thanks for the answer, Artur.
Just to conclude, does the error affect the software in any way (provided you just click ok and ignore it)?
Artur.Kosakowski
Autodesk Support
Autodesk Support
It does. The registration is required for Robot to work correctly.
Artur Kosakowski
