Error report in my file
Hi All!
I need some advice to fix this error
where to dowload if needed this .dll
Best Regards
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach this file please?
Artur Kosakowski
Thanks Artur
Attached the cropped file and the calculations settings
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do you intend to design this bar as a continuous foundation?
Artur Kosakowski
Please try also, If the soil ground conditions are deleted, the error persist
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to follow these steps:
If you still have issues attach a new version of the substructure as not having the entire file I'm not able to calculate the model after making this change.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Has the approach shown on the movie allowed you to solve the issue?
Artur Kosakowski
