When I'm trying to analyse my model I get an error "Incorrect data! Error Nr 100". Can you please let me know what this means so I can fix it up?
Jesper
Solved by Artur.Kosakowski. Go to Solution.
See:
Try to open the file in the repair mode.
Hi Artur,
I got the same message error, what should I do? Just renumber the nodes? I tried it, but it didn't work.
Gustavo
I've got the same problem with one Robot file. When i try to run the model the error 100 appear.
In my robot file there are nodes that does not exist. If i open the file in recover mode, the nodes mentioned earlier dissapear, but when i run the file the error appears again and the ghost nodes are created automaticaly.
How can i fix the file?
Paulo Marques
It is caused by inaccuracies in model geometry.
Take a look below (left part), some slab panel are not precisely meeting other panels and some additional calculation nodes are generated. (to have such view turn off DSC, run model generation and display calculation node numbers)
Run Detailed Correction to Structural Axes as shown below, then zoom to node 595 and correct panels corners (if required), then run Model Generation or Calculations.
I also removed panel 1573 - maybe you need it.
I also suggest to delete overlapping panels.
Model sent in PM.
or round up coordinates of ALL nodes \ panels \ objects using:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/td-p/3430533
