Error 5000 - For simple LTD model
m_sheinin
m_sheinin
I build a simple LTD model. And getting error 5000?  I'm running robot 2023 on the virtual machine. Can this be an issue?  I don't have a problem with others models.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @m_sheinin
Could you share the model for verification
(Save it as RTD without results and zip before sharing)
Krzysztof Wasik
mike_sheinin
Hi
See attached model.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @m_sheinin
It is very strange effect, but it seems that problem is caused by dimension lines.
After deleting dimension lines (particularly bottom dimension line), model can be calculated.
I will register that for verification.
Krzysztof Wasik
m_sheinin
Thanks you I will try you method on your end and will report back if it's solve the problem,
mike_sheinin
Hi @Krzysztof_Wasik,
Thank you for the solution. It did work.
