Empty steel design results table for South African Design code
Hi. Has anyone been able to use the Member verification or Group Design option with the South African codes? As far as i can see it doesn't work? If someone could verify this it would be nice. Thanks very much.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you give us more details on what doesn't work exactly?
Artur Kosakowski
Hi
When i run the verification on the standard setting which i think is set to British standard, it gives me results as indicated below.
Standard CodeStandard Code
Then i change the Design code to South African, then the results table opens but no results as below.
South African CodesSouth African CodesNoting in the TableNoting in the Table
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the SA version of the model?
Artur Kosakowski
Hi @Anonymous,
When you change the design code in Job Preferences, you must redefine the code parameters of elements - "Member type".
I hope I have helped.
Yip, That did the trick.
Thanks very much
