Elements not showing in Plan View
Hi there,
I've converted a model of 5 floor slabs at different levels from Revit 2016 to Robot 2016. They show up in the 3D view but once I try to look at them in Plan View they don't appear. I've overlaid DWG's at each level and they appear but the elements themselves do not. See images attached.
Secondly, the DWG's appear trimmed in the Plan View but appear in full in the 3D view (refer to the curved balconies in the Plan View attached).
Would greatly appreciate any help.
Cheers
James
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
See attached
Rafal.Gaweda
Autodesk Support
Autodesk Support
1. Correct stories and stories coordinates
2. Correct model  \ all objects should be defined on stories levels or staring \ ending on stories levels in your case
    To do so you can use Detailed Correct function or this tool:
    http://forums.autodesk.com/t5/robot-structural-analysis/panel-contour-points-modification-api/m-p/38...
3. Corrected model attached
Rafal Gaweda
