Column reinforcement changes when cover changes
Μηχανικος
Message 1 of 8
Μηχανικος
Hello everyone, i am using robot provided reinforcment to design a column.
Initially the provided reinforcement  calculated by Robot is 8Φ20 = 2513mm2     (with cover = 40mm)
Then the provided reinforcement  calculated by Robot is 12Φ20 = 3769mm2     (with cover = 30mm)
so why when i decrease my cover, the area of steel reinforcement increases?
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you send the file with both these columns please? Thank you.
Artur Kosakowski
Message 3 of 8
Μηχανικος
Below are the links for both columns.
http://www.mediafire.com/view/t44c48dlyqie822/1._Design_Response_Spectrum_-_Column_Design.rtd
http://www.mediafire.com/view/af2f5ctbieg16i0/1._Design_Response_Spectrum_-_Column_Design_2.rtd
These are exactly the same file except that in one i changed the cover distance within the Rc design module provided reinforcement
Analysis -> calculation options -> General -> Cover -> c >= 30 or 20mm
when i use c >= 30 the actual cover in the calculation is 40mm
when i use c >= 20 the actual cover in the calculation is 30mm
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
For 20 mm cover EC in 5.4.3.2.11 b imposes limits on main rebars tied by stirrups spacing as 20 cm (for 3 bars at at the side that would be 20.3 cm). For 30 mm cover the spacing is smaller that this code limit.
Artur Kosakowski
Message 5 of 8
Μηχανικος
Hi there is no such section (5.4.3.2.11 b) in EN 1992-1-1:2004
Message 6 of 8
Μηχανικος
Even if this is the case i dont think this is what is happening in my case. also i dont understand for which spacing limit you are referring to?
ok so when my cover is 40mm (30mm cover + 10mm deviation) i get 8 bars of 20mm diameter
and clear spacing between main bars is [500 - (2 x 40mm cover) + (2 x 10mm links) + (3 x 20mm main bars)]/2 = 170 mm
clear spacing between main bars is = 170mm
when i decrease the cover to 30mm i get 12 bars of 20mm.
and clear spacing between main bars is [500 - (2 x 30mm cover) + (2 x 10mm links) + (4 x 20mm main bars)]/3 = 113.33mm
clear spacing between main bars is = 113.33mm
what i am saying here is that if you decrease the cover and keep the same amount of main bars then the spacing between bars increases so why is Robot adding more bars?
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
 You can find the paragraph 5.4.3.2.11 b in  EN 1998-1:2004 (EC8, not EC2) which is used as you included seismic in your design:
The distance is understood as axial spacing rather than clear space between bars.
When cover is 40mm (30mm cover + 10mm deviation) and you get 8 bars of 20mm diameter, distance between axes of those bars = [500 - (2 x 40mm cover) -(2 x 6mm links) - (2 x 20mm main bars)/2]/2= 194 mm
This spacing is correct (194mm <200mm).
When you decrease the cover to 30mm and get 12 bars of 20mm, spacing between axes of main bars is [500 - (2 x 30mm cover) - (2 x 6mm links) - (2 x 20mm main bars)/2]/3 = 136mm
For 8 bars fi 20mm you would have [500 - (2 x 30mm cover) - (2 x 6mm links) - (2 x 20mm main bars)/2]/2 = 204mm which would be above the limit (>200mm)
Artur Kosakowski
Message 8 of 8
Μηχανικος
ohhhh i see, you are great, thank you for all your help, really appreciate this.
