[EC8 & Python code]
[EC8 & Python code]
xroguiez
Message 1 of 26
[EC8 & Python code]
xroguiez
Hello
I am trying to transform VBA code into Python from the example provided here: https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-seismic-case-definition/m-p/33578...
But I can't access the GetAnalysisParams() methods :
caseEdX = structure.Cases.CreateSimple(6, "Ed+X",
RobotOM.IRobotCaseNature.I_CN_SEISMIC ,
RobotOM.IRobotCaseAnalizeType.I_CAT_DYNAMIC_SEISMIC)
num_EdX1 = caseEdX.GetSeismicCode #is empty
#doesn't work num_EdX1 = caseEdX.Records.New(RobotOM.IRobotSeismicAnalysis_EC8_General_Params) #a validate
EC8params = caseEdX.GetAnalysisParams #is empty too
Can someone help me?
Thanks for any help
Xavier
Replies (25)
Message 2 of 26
Stephane.kapetanovic
Hi @xroguiez
You must declare your variable types
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 26
xroguiez
Hello
I agree with you but how to do it (in Python) ? I couldn't do it
Xavier
Message 4 of 26
> To declare a variable
Variable = Type_of_Variable (Class / Interface)
Example:
thData = IRobotThicknessData
> To Cast
Variable_0 = Type_of_Variable(Variable_1)
b = 125.3
print(int(b))
Output
125
Example:
label = RobotLabel(labels.Create(IRobotLabelType.I_LT_PANEL_THICKNESS,"25mm"))
therefore, you must declare the types of variables when necessary and check the output types of the functions according to the variables types to perform the casts
Best Regards
Message 5 of 26
See also
https://forums.autodesk.com/t5/robot-structural-analysis-forum/generate-ec8-general-seismic-case-thr...
Message 6 of 26
xroguiez
Hi
Thank you for all your advice.
I took the example in the link on the first 4 lines
VBA Source :
Dim ECParams As RobotSeismicAnalysis_EC8_General_Params
Set EQLoad = Robapp.Project.Structure.Cases.CreateSimple(200, "EarthQuake+X", I_CN_SEISMIC, I_CAT_DYNAMIC_SEISMIC)
Set ECParams = EQLoad.GetAnalysisParams
ECParams.Ag = Foglio2.Range("F9")
And then a partial version of Python transcription that works perfectly:
ECParams = RobotOM.RobotSeismicAnalysis_EC8_General_Params
ModalParams = RobotOM.RobotModalAnalysisParams
#I'm using different namespaces, but it's the same syntax
EQLoad = structure.Cases.CreateSimple(6, "Ed+X",
 The console proof, :
>>> dir(ECParams)
['Ag', 'B', 'BehaviorFactor', 'Direction', 'DirectionType', 'ExcitationDir', 'Filter', 'ResidualMode', 'S', 'Spectrum', 'Tb', 'Tc', 'Td', '__doc__', '__repr__']
dir(EQLoad)
['AnalizeType', 'CreateObjRef', 'Equals', 'GetAnalysisParams', 'GetHashCode', 'GetLifetimeService', 'GetSeismicCode', 'GetType', 'InitializeLifetimeService', 'IsAuxiliary', 'MainMode', 'MemberwiseClone', 'ModesCount', 'Name', 'Nature', 'NatureName', 'Number', 'Records', 'ReferenceEquals', 'SetAnalysisParams', 'SetNatureExt', 'TimeStepCount', 'ToString', 'Type', 'UniqueId', 'UserId', '__class__', '__delattr__', '__doc__', '__format__', '__getattribute__', '__hash__', '__init__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'label']
 But the next point is completely blocking, i don't understand how to cast :, in this attempt, the intial variable is erasing
#### here is my main cast problem...
>>> dir(ECParams)
['Equals', 'GetHashCode', 'GetType', 'MemberwiseClone', 'ReferenceEquals', 'ToString', '__class__', '__delattr__', '__doc__', '__format__', '__getattribute__', '__hash__', '__init__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__']
Another clumsy attempt :
>>> EQLoad.SetAnalysisParams(ECParams)
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
TypeError: Le cast spécifié n'est pas valide.
>>> EQLoad.SetAnalysisParams(ECParams())
TypeError: Cannot create instances of RobotSeismicAnalysis_EC8_General_Params because it is abstract
>>> ECParams.Ag = 1.
AttributeError: static property 'Ag' of 'IRobotSeismicAnalysis_EC8_General_Params' can only be assigned to through a type, not an instance
To be honest, i don't know in this how to cast it ? Could you help me ?
Thanks for all
Xavier
Message 7 of 26
How did you define EQLoad ?  EQLoad = RobotSimpleCase ?
Message 8 of 26
xroguiez
Hi again
Anothers attempts of casting :
>>> ECParams = RobotOM.IRobotSeismicAnalysis_EC_8_General_Params(caseEdX.GetAnalysis())
AttributeError: attribute 'IRobotSeismicAnalysis_EC_8_General_Params' of 'namespace#' object is read-only
>>> ECParams = RobotOM.RobotSeismicAnalysis_EC_8_General_Params(caseEdX.GetAnalysis)
AttributeError: attribute 'RobotSeismicAnalysis_EC_8_General_Params' of 'namespace#' object is read-only
The thing i don't really understand is the main difference between the two path... for the modal load, it's works :
caseMod = loads.CreateSimple(5, "Modale",
                                RobotOM.IRobotCaseNature.I_CN_EXPLOATATION ,
                                RobotOM.IRobotCaseAnalizeType.I_CAT_DYNAMIC_MODAL)
num_Mod1 = caseMod.Records.New(RobotOM.IRobotLoadRecordType.I_LRT_SPECTRUM_VALUE) #a valider
#loadRec = caseMod.Records.Get(num_Mod) #pas utile ici on l'applique au projet
modParams = caseMod.GetAnalysisParams()
modParams.Mode = RobotOM.IRobotModalAnalysisMode.I_MAM_MODAL
modParams.ModesCount = 50
modParams.Damping = 5e-2
caseMod.SetAnalysisParams(modParams)
These commands worked in Robot for the modal analysis and not for the seismic analysis
Xavier
Message 9 of 26
xroguiez
Hello
Like this ?
Is it right ?
Xavier
Message 10 of 26
xroguiez
Hi
I've used the following shortcuts
robApp.Project.New(RobotOM.IRobotProjectType.I_PT_SHELL)
project = robApp.Project
## IRobotStructure
structure = project.Structure  #IRobotStructure
Message 11 of 26
Before answer to other post
Code fail ↓
3 possible reasons :
- EcParams not defined as IRobotSeismicAnalysis_EC_8_General_Params type
- EqLoad not defined as a RobotSimpleCase type
- Try also
ECParams = EQLoad.GetAnalysisParams()
try to set preferences by SetActiveCode function as explain by cris.bac
there is also a remarks by Rafal Gaweda in your link
aaa = RCase.GetSeismicCode ' this is check only line, for EC codes there is no name returned here
'RobotSeismicAnalysis_EC_8_Params refers to ENV 1998-1-1:1994 DAN francaise, which is currently unused - if you are interested I can tell you how to enable this unused code
Best regards
Message 12 of 26
xroguiez
Hello
Thanks again for your help
If I understand correctly for the first point, it works for me ?
- EcParams not defined as IRobotSeismicAnalysis_EC_8_General_Params type, it seems to be right ?
>>> dir(ECParams)
- EqLoad not defined as a RobotSimpleCase type, same conclusion ?
>>> EQLoad = RobotOM.RobotSimpleCase
>>> dir(EQLoad)
>>> EQLoad = structure.Cases.CreateSimple(inumC, "Ed+X",
... RobotOM.IRobotCaseNature.I_CN_SEISMIC ,
... RobotOM.IRobotCaseAnalizeType.I_CAT_DYNAMIC_SEISMIC)
>>> dir(EQLoad)
-Try Also
Attempt 1 :the structure of ECParams has been deleted
>>> dir(ECParams)
Attempt 2 :the structure of ECParams has also been deleted
>>> dir(ECParams)
Attempt 3 : the structure of ECParams has also been deleted
>>> aaa = EQLoad.GetSeismicCode
>>> dir(ECParams)
Thanks for all
Xavier
Message 13 of 26
Is that works ?
could you write the correct integral sequence ?
Attempt 1, 2, 3 not working ?
Message 14 of 26
xroguiez
Hello
Sorry it doesn't works.
But what do you mean with the integral sequence ? I've posted all the code and the console return
Xavier
Message 15 of 26
yes all code in one thread please to resume because it's hard to follow for @JacquesGaudin, @cool.stuff, @1234eddie, @Rafal.Gaweda, @napooil.
Is this conclusion still true? with Python ?
Message 16 of 26
xroguiez
Hello
Sorry for this stream of unstructured information. I put everything in a single script ECM.txt (extension is not accepted). Is it ok ?
I'm running the script in IronPython2.7.12 and with Robot 2023. Do you have a solution to set the seismic parameters ?
Thanks for all
Xavier
Message 17 of 26
JacquesGaudin
With the line below, you can make sure that you are using the right default:
Robapp.Project.Preferences.SetActiveCode(I_CT_SEISMIC_LOADS, "EN 1998-1:2004/A1:2013-General")
The type of seismic params depends on this setting. If you put this line before defining the seismic load case, you should get the correct type of params.
Note: In Python, you need the brackets to call a function. Without brackets, you are referring to the function / method object.
Message 18 of 26
To obtain codes numbers and names
Preferences = RobotOM.RobotProjectPreferences
Preferences = robApp.Project.Preferences
#Preferences.SetActiveCodeNumber(RobotOM.IRobotCodeType.I_CT_SEISMIC_LOADS, 000)
#Preferences.SetActiveCode(RobotOM.IRobotCodeType.I_CT_SEISMIC_LOADS, "XXX")
CodeNumber = Preferences.GetActiveCodeNumber(RobotOM.IRobotCodeType.I_CT_SEISMIC_LOADS)
      Code = Preferences.GetActiveCode(RobotOM.IRobotCodeType.I_CT_SEISMIC_LOADS)
Table (to be continued) to match seismic codes and Params
# Nbr ! Code                                          ! Params
# 136 : "EN 1998-1:2004/A1:2013"                      ! RobotSeismicAnalysis_EC8_Params
# 137 : "EuroCode 8 2003 (General)"                   ! RobotSeismicAnalysis_EC8_General_Params
# 137 : "EN 1998-1:2004/A1:2013-General"              ! RobotSeismicAnalysis_EC8_General_Params
# 148 : "NF EN 1998-1/NA:2007 19.juil.2011"           ! ???
# 162 : "NF EN 1998-1/NA:2013 DÉCEMBRE 2013"          ! ???
# 163 : "NF EN 1998-1/Nice PPR/NA:2007 19 juil. 2011" ! ???
# TBC :                                               !
Message 19 of 26
xroguiez
Hi
Here are the 2 codes I got
>>> preferences = robApp.Project.Preferences
>>> CodeNumber = preferences.GetActiveCodeNumber(RobotOM.IRobotCodeType.I_CT_SEISMIC_LOADS)
>>> Code = preferences.GetActiveCode(RobotOM.IRobotCodeType.I_CT_SEISMIC_LOADS)
>>> print(CodeNumber, Code)
(162, u'NF EN 1998-1/NA:2013 D\xc9CEMBRE 2013')
I was not able to access the objects by trying the 2 methods
>>> EC8 = RobotOM.RobotSeismicAnalysis_EC8_General_Params
>>> EC8.BehaviorFactor = 1.
AttributeError: static property 'BehaviorFactor' of 'IRobotSeismicAnalysis_EC8_General_Params' can only be assigned to through a type, not an instance
>>> EC8 = RobotOM.RobotSeismicAnalysis_EC8_Params
AttributeError: static property 'BehaviorFactor' of 'IRobotSeismicAnalysis_EC8_Params' can only be assigned to through a type, not an instance
Thanks for any help
Xavier
Message 20 of 26
as indicated in the correspondence table, code 162 does not seem to have a functional interface among the three available
