EC3 design parameters
kostastomp
kostastomp
Hi everyone,
Could somebody please explain to me what do these parameters shown below mean?
The help menu doesn't say much about them.
1) On the first image: If I define a buckling length, or select one of the predefined options, does it make any difference if I say that the member is sway or non sway? When should I use this option?
2) On the second image: Do pipes refer to hollow sections in general, or just round pipes? I am asking becuase further below it distinguishes and asks more specifically for round pipes.
Also what is this f_yb and f_ya parameter? Any reference to the Eurocode please?
Excuse my basic questions, but I would like to know exactly what the software does and not just use it as a black box.
K
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @kostastomp
Ad1 Buckling length coefficient calculation
When sway option is on automatic procedure for buckling length coefficient calculation
allow element horizontal displacement ( frame with no bracing)
In most cases buckling coefficient calculated automatically will be >1
When non-sway option is on, automatic  procedure for buckling length coefficient calculation does not allow element horizontal displacement ( frame with bracings)
In most cases buckling coefficient calculated automatically will be <1
Ad2.
Fyb and Fya refers to cold formed sections, EN-1993-1-3
paragraph  3.2.2 Material properties of cold formed sections and sheeting.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
paul.bassLH
1) the difference may be illsutrated with these two screenshots.
Non-sway structureNon-sway structureSway structureSway structure
2) It is not clear. To be honest, i don't know :/. Maybe just to condiser that hot rolled pipe have a yield stress slightly lower than cold formed pipe. Someone else have an idea ?
Regards
kostastomp
Thank you both.
Paul, I know what a sway and and non-sway frame is. The fact that the sway-non sway button is not greyed out when selecting one of the standard (non automatic) buckling length settings.
