Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Mouhammad_mazzaz
229 Views, 1 Reply
DOME
Hello every one
I have make two model of a dome with the same dimension
the first model is a dome supported on a liner pinned support
the second model is a dome supported on a circular wall and the wall supported on a liner pinned support
when i show the stresses on the dome in the two model
The results are different
what is the reason of this ?!
1 REPLY 1
Hi @Mouhammad_mazzaz
My assumption is that you disregard the fact that walls actually move in the horizontal directions and 'drag' the dome.  In addition mind the smoothing option stetting for the dome + walls model.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
