Distribution reinforcement
MUHANNAD.ABU_ABDO
Message 1 of 11
MUHANNAD.ABU_ABDO
I'm working at unrwa .and i use BeamD to design reinforced concrete frames ? now we bought Robot structural analysis 2015 and i'm wondering if it's possible to distribute reinforcement in the frame section like in the pic ( cage method ) because this way is more practical to us .. i hope get answer as soon as possible
Muhannad M.Abu Abdo
Structural Design Engineer
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 3 of 11
MUHANNAD.ABU_ABDO
Thanks for your response .. look at this pic ?
Muhannad M.Abu Abdo
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Too narrow beam?
Artur Kosakowski
Message 5 of 11
MUHANNAD.ABU_ABDO
No .. and the depth of frame 600mm so if there's problem .. the robot must distribute the reinf. on layers ??
Muhannad M.Abu Abdo
Message 6 of 11
MUHANNAD.ABU_ABDO
Muhannad M.Abu Abdo
Message 7 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Attach the file with the beam and make the sketch of the intended reinforcement arrangement.
Artur Kosakowski
Message 8 of 11
MUHANNAD.ABU_ABDO
Here is Robot & Autocad file for reinf. arrangement
thanks in advance
Muhannad M.Abu Abdo
Message 9 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
You need to set the single span segment to divide reinforcement. "Vertical" U shape rebars as main reinforcement are not supported in Robot.
Artur Kosakowski
Message 10 of 11
MUHANNAD.ABU_ABDO
Ok fair enough ... i hope see this option in the next versions of robot .. but the problems with reinf arrangements still ??
Muhannad M.Abu Abdo
Message 11 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
No.
Artur Kosakowski
