how much time RSAP needs to display maps for load combinations? I have a slab model composed of 15000 nodes, 250 load combinations and it takes a very long time. Is it normal?
RSAP 2024
CPU: Intel Xeon E5-1620 QUAD 4x3.6GH (during use RSAP utilization at 13%)
GPU: NVIDIA Quadro K2200
Solved by teixeiranh. Go to Solution.
Solved by Rafacascudo. Go to Solution.
If you are asking for an envelope map for many combinations it can take a long time(minutes) if the panel is very large depending on the computer specs
Rafael Medeiros
For a model of a slab with 15k nodes it can take sometime, yes.
I find that, even with good machines, models with more than 20k nodes start to be difficult to work with. Too slow.
If your machine is not that good you are going to need some patience.
Try to reduce the number of nodes, you are better of with a workable model, the precision model that you have maybe is not workable because it takes a lot to calculate. You may get good results with 10k nodes or less.
