Display Error: Tabs bar overlapping window
jo2ny
Message 1 of 11
jo2ny
I'm having a display error that prevents me from accessing some settings in various windows of the program.
The tabs bar is overlapping the window. Thick boxes under this tabs bar are inaccessible.
Please see attached picture.
Is there any way to fix it?
I'm running Autodesk Robot Structural Analysis Professional 2017 on a Win 10 machine.
Thanks in advance,
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
W10 or W10 with Anniversary Update?
Rafal Gaweda
Message 3 of 11
jo2ny
W10 with Aniversary Update
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try without it.
Rafal Gaweda
Message 5 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI,
Before taking the step proposed by Rafal try to rename this dll.
c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2017\DTabControlSelector\Autodesk.Common.DTabControlSelector.dll
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 6 of 11
jo2ny
I renamed the indicated dll. and the tab bar disappeared.
This works for me, as i didn't use that bar anyway.
Thanks!
Message 7 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
One more thing to check. Do you have your Windows task bar on the left hand side of the screen rather than at the (default) bottom? If yes, try to restore the dll and move the Window task bar at the bottom and check how thy look like.
Artur Kosakowski
Message 8 of 11
Hello
i am having the same issue. Using ROBOT 2017 in windows 7 (Enterprise) SP1
You said, Rename the dll file. but Rename to what?
Can i rename to what ever?
Please clarify this
thanks in advance.
Vijay
Message 9 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Yes, just change the name to e.g. add 1_ in front of the oroginal file name.
Artur Kosakowski
Message 10 of 11
Hello
yes, i have tried this, as someone said in earlier replies, The tabs totally disappears now.
Its OK now. I tried with changing start bar to bottom as well.( usually i prefer on left side start bar)
Vijay Krishna
Message 11 of 11
okapawal
This issue has been resolved with Robot Structural Analysis Professional 2023 release.
Please find more in the Release Notes
Regards
Autodesk Robot Structural Analysis team
Waldemar Okapa
Software Quality Assurance & Testing Engineer
