Discrepancies in results for rebar
I analysed a slab and found max moment to be over 3000kNm/m but when checking required reinforcement, the max area was 1342mm2/m. This area would provide less than 1000kNm/m resistance. Why would this happen?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the model as well as screen capture showing what exactly to look at and your hand calculations?
Artur Kosakowski
It's OK actually. I realized its only a very small area in which the moment is very high
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to display moments with reduction over supports as this is the default settings for reinforcement calculations as this may be the reason for the difference you noticed.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
