Direct Analysis Method (DAM)
ArasRahman
ArasRahman
Why is RSA extremely weak in P-Delta analysis? I have never run a non-linear load case without getting no coverage error or matrix is not positive, I have attached a simple model, I will be thankful for anyone who can solve my problem.
Simau
Hi @ArasRahman
You can’t use full automatic combinations in non-linear analysis, use instead manual combinations generate.
In non-linear parameters check matrix update after each iteration
Model attached
M. Agayr
ArasRahman
I am still getting the same error when I run DAM model, any suggestions please ?
Simau
Hi @ArasRahman
The title of your post should be Direct Analysis Method
M. Agayr
