07:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am modelling a building that contains 4 small voids in the middle. I want to apply a load in an area that contains the voids and a different load outside of the middle box and repeat it to all stories above.
1- I tried to create a new panel in the middle so I can input a different load in that zone but the voids will still belong to the larger panel.
2- I tried to create a planar load on contour but the load will only be applied at the defined height therefore it won’t repeat to the stories above.
Is there a solution to apply different loads in this particular situation?
Marco
