difference in steel code calculation
This widget could not be displayed.
Hello, you can find in the attached structure that two bars (1 and 4 in the model) having the same forces form combination 4 are calculated with a major diference in the utilisation raport. Where does this difference come from considering the bars have same forces in them?
Thank you.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Due to the slight inaccuracy of the position of the bracing and the cladding the detection of the maximal bending moment for stability check is at the 'wrong' side of the bracing.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
I do not understand, is the model incorrect, or it is robot's fault? how can i prevent this from happening?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
To avoid this situation I'd create a model in the way I suggested during the 3rd RSA webinar:
This also shows that the bracing should be set at 0.52L rather than at 0.54L for the previous solution.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
