I have two slabs with the same load, P=1000 kN i center. I have a question about diference in tension results because they are completely other.
1. Massive slab hight=60cm, KZ=6000
2. Panel slab hight=60cm, KZ=6000
How Robot is calculate thension in this case?
I have to calculate raft foundation with hight = 3 m, so what type of measurement I must used to callculate tensions in reinforced? I will be lucky if someone explain me this problem, also I attached two pictures with examples.
Than YOU!!!
