Difference between moments in results tab and RC Design
engenharia5EZVM9
engenharia5EZVM9
Hi all,
I'm starting to use Robot and running some tests. I realized that the max negative moments given in the results tab is different from the one presented in the RC design, as shown in the imagens attached.
As seen, both max theoretical and redistributed negative moments shown in the RC design screen (0.33 KN.m) are diffrent from the diagrams in the results tab (0.50 KN.m). So I figure it's not the redistribution process causing this.
Can anyone help to understand.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @engenharia5EZVM9
In RC module Robot shows moment at column face. Column size is taken into account.
Krzysztof Wasik
engenharia5EZVM9
But considering this, doesn't it use a smaller moment than it should?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @engenharia5EZVM9
If you are using eurocode  2
5.3.2.2 (3) Where a beam or slab is monolithic with its supports, the critical design moment at the
support should be taken as that at the face of the support.
Krzysztof Wasik
engenharia5EZVM9
In fact, i'm using Eurocode as a reference, but the objective is to adapt to the Brazilian standards.
Many thanks!
zeeblake
Does Robot also consider the note in EC2 just below that paragraph, that says "The moment at the face of the support should not be less than 0,65 that of the full fixed end moment." ?
I'm doing some tests, and I managed to get in a span a negative moment for RC design less than 0.65 the full fixed end moment, so ... does Robot consider that?
zeeblake
Does anybody know this?
