Diaphram definition (large displacements and rotations)
omarsQSKVQ
Message 1 of 8
omarsQSKVQ
I have a building consists of two full area (352*462 ft) mezzanine floor
the system is a steel one way decking, released main beams and joists and the decking supposed to transfer the lateral loads to the braced frames for the 4 outer elevations (all supports are pinned)
as per the attached snapshot also i attached a simple model that i face same problem in define this concept
i tried the rigid link , panel calculation model (membrane) also i tried shell with a custom definition with 0 bending and shear stiffness i really get bored so please help.
Replies (7)
Message 2 of 8
Simau
Hi @omarsQSKVQ
Just add some horizontal bracings
Model attached
M. Agayr
Message 3 of 8
omarsQSKVQ
Do you think i need to add horizontal bracing "Is it a must? "
or the composite slab work as a diaphram to transfer the load to the vertical bracing
the attached snapshot from Design Examples  (AMERICAN INSTITUTE OF STEEL CONSTRUCTION)
is it the same system ?
Message 4 of 8
Simau
Another solution is to use an orthotropic slab of thickness equivalent in weight to your one way deck.
Here, i assumed your composite deck have a SW of 1.5 kN/m² then equivalent to a 6 cm thickness orhotropic deck.
Model attached
M. Agayr
Message 5 of 8
Refaat
Hi @omarsQSKVQ
1. Pinned -Pinned release ( only Ry ) .
2. Remove the click from (Disregard density) since the self-weight is excluded from mass participation.
3. Delete duplicate case (6) from the converted cases
4. The modified file is attached.
Message 6 of 8
omarsQSKVQ
I can't thank you enough for your help.
For the seismic mass participation  definition, Is it okay to define it as per the attached snapshot?
and one more question, I don't need to define panel thickness aright?
I think whole the trouble because of the wrong releases definition.
really thanks again.
Message 7 of 8
Refaat
Hi @omarsQSKVQ
Yes
Possible if diaphragm is used as well the slab weight considered as uniform load . Define the slab thickness is more preferable.
Certainly
Message 8 of 8
Simau
Hi @Refaat
Maybe the releases hypothesis was a company requirement who did not want to bother with MZ bending moment in the connections.
M. Agayr
