Is there any module in Robot in which I can get the stresses and strain values at each point/fiber in a RC section? I know that you can see the neutral axis for each combination of actions in columns, but in beams I wasn't able to find how to find where's the neutral axis for a given combination in a given section. Also, it would be very helpful to see the stresses at the concrete (following the stress/strain diagram you use, which I don't know if it's the rectangle block or the parabola-rectangle) and in the reinforcement. The closest I found are the "Strains" and "Stresses" diagrams of the calculation note in a beam, but they provide a single value for each section (I suppose it's the maximum), while what I'd want is to see the stress and strain at each point in the section.
BTW, if this is not implemented, can I at least get the numerical value of the depth of the neutral axis? Is it in some place of the calculation note, or can I get it from some other window in Robot?
Thanks a lot!
