Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Design result showing as failed?
3 REPLIES 3
Tmanzz
232 Views, 3 Replies
Can someone kindly have a look at the attached model and let me know why member 2 is showing as failed?
All the calc notes seems to suggest capacities are not exceeded but there is an 'x' next to the member name.
thank you
3 REPLIES 3
Simau
in reply to: Tmanzz
@Tmanzz
It's because displacement is not verified
Look at calculation note
M. Agayr
Krzysztof_Wasik
in reply to: Tmanzz
Hi @Tmanzz
Member 2 fails due to excessive ux displacement of top node (in respoect to bottom node). Limit L/300 is set for that member
Krzysztof Wasik
Rafacascudo
in reply to: Tmanzz
It seems nodal displament is excessive
Rafael Medeiros
