design of short column BS8110
in BS 8110  .... in order to find Ultimate axial load capacity
I've tried dozens of example using Robot ....
Robot alway give different results
should interaction diagram & these equation give the same results?? or even clos results
I've attached an example
a column having 196 ton Ultimate load
if we use any of these eqaution it gives ultimate load capacity of 169 & 192 Ton
which means it's unsafe
Concrete used C25
Fy=3600
any Ideas ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
This approach is not implemented in Robot. The design of RC Columns according to BS is always done according to the paragraph 8.3.2 Moments and forces in columns and in the situation there is no bending Robot assumes the provisions of the paragraph 3.8.2.4 Minimum eccentricity.
Artur Kosakowski
