Design of beam supported by a panel
Μηχανικος
Message 1 of 12
Μηχανικος
I am trying to design a beam that is supported by a panel (shear wall) on one end and by a bar (column) on the other end. see picture below.
When i import the beam in the Provided reinforcement module, Robot does not recognise the wall as a support and considers that the beam is a cantilever supported only by the column on one side, see picture below. How can i solve this?
could this have implications on the anlaysis?
When i import the beam in the design module it gives me the option to select the supports but the support given there is a node on the slab.
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Mark both check boxes during the import and adjust the width of the wall support if needed inside the RC Beam design module.
See also:
https://screencast.autodesk.com/Main/Details/d80b5426-d4da-47a2-bcc6-2c322696411a
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 12
Μηχανικος
I did try that before posting and something strange happened, the design module brought up the design for a foundation, however now irs working great.
Message 4 of 12
Μηχανικος
I have one more issue regarding the same subject.
Now i am trying to import 3 beams into the provided reinf. module.
As you can see from the picture below, beam No.1 is separated from the other two beams by a panel (wall), while the other two beams No.2 & 3 are continuous.
At the supports tap i have ticked all the members, and i even tried different combinations (see below).
However the module only imports beams No. 2 & 3 together in the same module and imports beam No.1 on its own in another module. Any ideas would be greatly appreciated.
Message 5 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
The easiest would be to replace a wall with a column (bar element).
Artur Kosakowski
Message 6 of 12
I have problems adjusting the support width as i did not get the principle of it from the explanatory video.
This is the beam i'm trying to design in the RC Beams module with those walls as supports.
The beam with the walls and span dimensionsThe beam with the walls and span dimensionsafter importing the beam to the moduleafter importing the beam to the moduleAfter adjusting the walls dimensionsAfter adjusting the walls dimensionsAfter adjusting the offsetsAfter adjusting the offsetsP5.PNG
After adjusting the support width for both sides, the beams span shrinks. I tried to adjust the offsets as shown in the video, i got the correct beam span however the beam connected to it (shown in previous pictures) disappeared and the moment diagrams shifted as if the beam itself was stretched.
These are the offsets used:
Any Help??
Message 7 of 12
Hi @Artur.Kosakowski
i havent got any answer yet.
Message 8 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I wish I could answer everybody in no time but it is not doable Smiley Sad
Could you attach the model?
Artur Kosakowski
Message 9 of 12
Thank you @Artur.Kosakowski for your continuous support.
i've attached a model with a lot of examples of beams supported on walls that need width editing when exported to rc beam module.
Moreover, i've noticed that the moments and shear differ between the model and the rc beam module. If you could check it out aswell or is there any explanation why.
Johnny
Message 10 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Which beam (bar number) is it and which load case or combination is the diagram for?
Artur Kosakowski
Message 11 of 12
The bar number is 106 and for combination 4: 1.2D + 1.6L
Message 12 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
As Robot assumes end nodes of a beam in a model being in the centers of te supports you need to either:
- define this beam as a 'longer' one till the middle of the'width' of the support you want to decide on during reinforcement design
or
- change the support type to masonry
For the maximal moment in the span it is the accuracy of the number of points the values are taken from
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
