I am currently trying to complete the meber design for a structure which I am designing. Currently some of the members are not passing the code checks and when investigating the reason for this, I have come acrss discrpencies between the member forces listed in the forces table and those used in the design note for the meber.
For example, consider beam 56 in the attached model. From the force table I obtain:
But compare this to the design note which lists the following design forces:
The meber forces in the design note are significantly higher than those in the forces table - can you explain why this discrepancy occurs? I am using ASD 1989 to verify the structure as parts of it are existing and were originally designed to this code.
NOTE: The uploaded model was saved without results to limit file size.
