Design error using Section builder model.
Tmanzz
Tmanzz
i have created a section using the section builder from Robot.
i have used this for a design and coming up with an error during member verification check.
Any idea what i have done wrong? thanks
Model attached using robot 2023.
Stephane.kapetanovic
hi @Tmanzz
before Saving Section to the Database and if want to justify it, it is important to provide additional information.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Tmanzz
thank you @Stephane.kapetanovic
My section consist of plates that are wider than the column width.  So my 'b' is not consistent.
Which dimensions will the system use to calculate the section properties? The section i have drawn or the additional information i have used?
hi @Tmanzz
first try the minimum thickness and the wider flange.
Best Regards
CaioSaporito
Hi @Tmanzz.
I believe this adittional dimension is only used to local buckling verification. Puting the values that Stephane said you will be on safe side.
The "global" section proprietes will be made from real section dimensions that you have drawn.
Best regards,
Caio
