Definition Bidirectional slab
Hello!!
I want to define a bidirectional slab of (70+10)*(25+5) cm
This is correct?
What is the parameter Esp =12.1 cm? equivalent thickness??
Thanks!!!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Th - the equivalent thickness used to calculate the plate self-weight.
http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-2000B438-5453-4C90-B658-E3DE6F8AF33A
Rafal Gaweda
But, Is the slab well defined?
I ask this question because when I calculate the reinforcement, Robot give me a error
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to define "flanges" as a panel and ribs as beams. Then design reinforcement for a panel in ten RC Slab reinforcement module and for beams in RC beam reinforcement one. See:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/T-slab/m-p/3185418
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Beam-offsets/m-p/3332921
for design of beams.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
