Deferential edge load on cylinder
jsaayman
Message 1 of 8
jsaayman
Hi
I'm designing a foundation for a large cylindrical structure and I need want to convert the wind load on the side of the structure to a couple, but I would like to apply this couple force as a differentially distributed edge load. How would I go about doing something like that?
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @jsaayman
Could you attach some pictures which illustrate what you want to achieve?
Artur Kosakowski
Message 3 of 8
jsaayman
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @jsaayman
What about something like that?
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 8
jsaayman
Hi @Artur.Kosakowski
Please could you give me some guidance on how to add the rigid links. I've never been able to do it successfully in Robot.
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @jsaayman
Try like that:
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 7 of 8
If you want to size the foundation I think, it is more simple to determine the tensor at the center of gravity of your fondation and use them for your calculations...
Message 8 of 8
Hi Rafal,
could you please confirm me that ''blocked all'' in rigid links (in this case) is appropriate!
Regards
