Deep beam vs regular beam
safet_iska
safet_iska
Hi
Im trying to do a deep beam calculation and firstly want to double check the results compared to a regular beam if I use the wall tool.
I´ve modelled similar geometry just used a wall and other example a beam, when I try to figure out the moment in local y I get a certain value, but I have a hard time to translate the results from the wall and the nyy results which should present the "moment" force in plane direction.
How do I recieve the max moment in the wall scenario? is it the results (-17,93 kNm)?
See picture attached and the max moment on the normal beam, it differs alot.deep beam.jpg
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @safet_iska
Please share this model for verification. Reduced moment for panel cut should present bending moment in wall element
Krzysztof Wasik
safet_iska
Thanks for quick response, I´ll upload it here.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @safet_iska
In your model wall have different supports than beam.
Upper supports generates horizontal and vertical reactions (so it is a kind of fixed support)
Additionally to avoid horizontal reactions in bottom supports you have to release UX in one of them
See modified model with similar support systems.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
