- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
Im trying to do a deep beam calculation and firstly want to double check the results compared to a regular beam if I use the wall tool.
I´ve modelled similar geometry just used a wall and other example a beam, when I try to figure out the moment in local y I get a certain value, but I have a hard time to translate the results from the wall and the nyy results which should present the "moment" force in plane direction.
How do I recieve the max moment in the wall scenario? is it the results (-17,93 kNm)?
See picture attached and the max moment on the normal beam, it differs alot.
