Custom Shape Thrust Block
Message 1 of 8
Hi all,
I am looking to create a custom shape thrust block for a supporting considerable loads from a space frame structure. I am new to Robot (however, fairly competent in Revit) and haven't a clue where to start when defining such complex geometry. The geometry involves blending a larger sketch into a smaller sketch - as shown in the badly drawn picture - and shall be constructed using reinforced concrete.
Does anyone have any ideas on how to go about this?
Cheers,
Murray
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Murray,
What kind of a model is it? A solid? What kind of the results do you need to get from Robot?
Artur Kosakowski
Message 3 of 8
Hi Artur,
I think, intially, yes. It may be modelled as being hollow later but for now a solid would be perfect. I need to get the required area of rebar.
Thanks again,
Murray
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
For a solid you may consider modelling a solid with complex shape outside Robot and import it as a *.sat file however Robot is not able to calculate reinforcement for solids.
Artur Kosakowski
Message 5 of 8
Hi Artur,
Thanks for your reply. Apologies, I am new to Robot - how would I need to model it such that I can calculate the reinforcement required?
Thanks again,
Murray
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Robot can only calculate reinforcement for surfaces (shell element types) which means that your 'object' has to be a 'hollow' one with 'walls' and top and bottom 'slabs' rather than a solid.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 7 of 8
Artur,
Ah right, I follow. Is that a relatively easy procedure? The walls would need to be sloped to replicate the geometric shape of the thrust block.
Murray
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to model them as number of 'vertical' panels defined by four edges with top a bottom being curved.
Artur Kosakowski
