Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As you can see in the attached image zg is considered positive in columns_left analysis and negative (same value) for columns_right....thus, different Mcr values have been calculated...(verified by hand as shown here http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Critical-moment/m-p/3335273/highlight/true
Is it possible to have negative values for zg since it's a distance?
Shouldn't both left and right columns have the same zg value since both are loaded on the upper flange which is also the restained one...
