Creating and transfering templates
Hello. I want to create in the Robot new "standards" with especific materials, sections, calculation parameters, etc. How can I do it and transfer these standards/templates between different computers?
Thank you, Marcelo Rodacki.
Artur.Kosakowski
Autodesk Support
Autodesk Support
All the new settings will be stored in these folders:
user section databases, material databases, etc.
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\201x\
configuration files, RGL files
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 201x\CfgUsr\
In addition you may also look at the content of thsi folder:
C:\ProgramData\Autodesk\Structural\Common Data\201x\
If you copy them to other computers the changes made on the 'source' one will be available on other machines as well.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
