Create foundations. IRConcrFooting Interface.
jmmarin
Message 1 of 10
jmmarin
Hi all.
I'm trying to instantiate a "foundation" object for a project in VB.net.
Perhaps due to lack of knowledge, I am unable to declare the object and be able to access. Here's the code I've started:
        Dim roboFooting As IRConcrFooting
        roboFooting.CalculationOptions.Cover = 0.05
        roboFooting.Concrete.CharacteristicStrength = 30
        roboFooting.Ground.SoilLevel = -2
        roboFooting.Geometry.Type = IRConcrFootingType.I_CFT_FOOT_TYPE_FOOTING
        roboFooting.Geometry.Shape = IRConcrFootingShapeType.I_CFST_FOOT_SHAPE_RECT
        roboFooting.Geometry.PierType = IRConcrFootingPierType.I_CFT_FOOT_PIER_TYPE_DOWELED
        roboFooting.Verify(True)
The error message is the following:
https://learn.microsoft.com/en-us/dotnet/visual-basic/language-reference/error-messages/variable-var...
Any  guidance to understand the concept is welcome. I'm just a learner getting into the API.
Thanks in advance.
Replies (9)
Message 2 of 10
Stephane.kapetanovic
hi @jmmarin
type is defined
but value is not set, create it by Create method from IRobotProjectComponentMngr
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 10
jmmarin
Hi @Stephane.kapetanovic.
Many thanks for your reply. It was very helpful because now object is created. However, I do not know how to call to the object created. I have tried "get" method but it throws an error (it seems I am trying to use the same way than VBA and COM libraries). This is the code:
        roboPro.ComponentMngr.Create(IRobotProjectComponentType.I_PCT_FOOT, "Footing", "axb")
        roboFooting = roboPro.Get(IRobotProjectComponentType.I_PCT_FOOT, "Footing")
I really don't know how to declare the object (footing) so I can modify it. Can you correct the current code or add what is needed?.
Thanks.
Message 4 of 10
hi @jmmarin
try this (don't forget to define loads, concrete strength, bottom reinforcement, etc.)
Sub CreateFooting()
    Dim RobApp As New RobotApplication
    Dim ComponentMngr As RobotProjectComponentMngr = RobApp.Project.ComponentMngr
    Dim ProjetComponent As RobotProjectComponent
    With ComponentMngr
        ProjetComponent = .Create(I_PCT_FOOT, "Footing", "axb")
        Select Case ProjetComponent.Type
            Case I_PCT_FOOT
                Dim ConcrFooting As IRConcrFooting = ProjetComponent.Data
                With ConcrFooting
                    With .Geometry
                        .Type = I_CFT_FOOT_TYPE_FOOTING
                        .Shape = I_CFST_FOOT_SHAPE_RECT
                        .PierType = I_CFT_FOOT_PIER_TYPE_DOWELED
                    End With
                    .Verify(True)
                End With
        End Select
    End With
    RobApp = Nothing
End Sub
Best Regards
Message 5 of 10
note that you can iterate over a collection of project components
Sub IterateOverFootingCollection()
    Dim ComponentCollection As RobotProjectComponentCollection = RobApp.Project.ComponentMngr.Get(I_PCT_FOOT, "axb")
    Dim ConcrFooting As IRConcrFooting, ConcrContinuousFooting As IRConcrContinuousFooting
    For i = 1 To ComponentCollection.Count
        ProjetComponent = ComponentCollection.Get(i)
            Case I_PCT_FOOT
            Case I_PCT_CONTINUOUS_FOOT
                ConcrContinuousFooting = ProjetComponent.Data
        End Select
    Next i
    RobApp = Nothing
End Sub
Message 6 of 10
jmmarin
Many thanks! Thanks to your explanation I have understood what I was doing wrong.
In addition, I have modified some parts of the code since I am developing in VB.NET and it is different to VBA in some aspects. For instance, "set" is not allowed.
Best regards.
Message 7 of 10
durducgeorge
Hello Mister Kapetanovic,
Do you know how can I define loads for the foundations?
The interface IRConcrFootingLoads doesn't have any methods....
Thank you
Message 8 of 10
hi @durducgeorge
That was the thrust of my advice in the previous message (loads, concrete strength, reinforcement, etc.).
For loads, you can specify the nodes in your structure that correspond to your foundation.
With ConcrFooting
  '[...] Do something
  .CreateFromNodes "1"
  '[...] Do something
End With
for standalone mode, note that it is still possible to create two nodes, a support and a bar, and to apply loads.
Sub CreateColmunAndForces()
    RobApp.Project.New(I_PT_FRAME_3D)
    With RobApp.Project.Structure
        With .Nodes
            .Create(1, 0, 0, 0)
            .Create(2, 0, 0, 1)
            .Get(1).SetLabel(I_LT_SUPPORT, "Fixed")
        End With
        With .Bars
            .Create(1, 1, 2)
            .Get(1).SetLabel(I_LT_BAR_SECTION, "IPE 100")
        End With
        Dim DL As RobotSimpleCase, LL As RobotSimpleCase
        Dim recDL As IRobotLoadRecord, recLL As IRobotLoadRecord
        Dim Cnvt As Double : Cnvt = 1000
        With .Cases
            Dim Tv() As IRobotNodeForceRecordValues = {I_NFRV_FX, I_NFRV_FY, I_NFRV_FZ, I_NFRV_CX, I_NFRV_CY, I_NFRV_CZ}
            Dim TbDL() As Double = {1.5, 1.5, -10, 0, 0, 0}
            DL = .CreateSimple(1, "DL - Footing Permanent", I_CN_PERMANENT, I_CAT_STATIC_LINEAR)
            recDL = DL.Records.Create(I_LRT_NODE_FORCE) : recDL.Objects.FromText("2")
            For i = 0 To 5 : recDL.SetValue(Tv(i), TbDL(i) * Cnvt) : Next
            Dim TbLL() As Double = {5, 5, -25, 0, 0, 0}
            LL = .CreateSimple(2, "LL - Footing Live", I_CN_EXPLOATATION, I_CAT_STATIC_LINEAR)
            recLL = LL.Records.Create(I_LRT_NODE_FORCE) : recLL.Objects.FromText("2")
            For i = 0 To 5 : recLL.SetValue(Tv(i), TbLL(i) * Cnvt) : Next
        End With
    End With
    RobApp.Project.CalcEngine.Calculate()
    RobApp = Nothing
End Sub
It would also be beneficial to add a CreateLike and Get method for iterating over collections.
Unfortunately I can't help you more about foundations than to give you some additional ideas and advice on how to get over the programming hurdles.
In the event of an update planned by Autodesk with the idea of replacing the CEB justifications by EN 1992-4 for steel column bases, it would be useful if the dimensioning of foundation blocks in the new Eurocodes could provide the additional reinforcement required for the anchor rods.
Best Regards
Message 9 of 10
durducgeorge
Hello Mr. @Stephane.kapetanovic,
I thought that I can introduce directly my reactions into table loads of my footings already created in RC Elements Design (without creating nodes bars etc.).
Thank you very much for your solution and for the rapidity of your answer.
Message 10 of 10
ext_julien_lebertMYQZ9
Hello, thanks for all the explanation. It's really helpful.
But I have a problem. I can't choose many parameters, like those who are in "Story Parameter" or "Footing Reinforcement". Can you help me, please?
