does any one know how to display results for core walls, one wall at a time? i.e. for the wall which has been selected for display? I have defined the core walls and gone to diagrams for buildings and core walls, however when I select the results I want i.e. FZ in this case, it shows this for all core walls which gets a little cluttered on the view. see attached pdf, is there a way of selecting the graphical results for each core wall to be shown one at a time?
Solved by Artur.Kosakowski. Go to Solution.
Check this movie:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
