Core Wall vs Shear Wall
1 REPLY 1
1556 Views, 1 Reply
I have an issue with core wall results
If you check the internal forces for the walls separately, you'll find out that the moments on walls are within an average of 1500 kN.m , and the shear is around 700 kN. Also, when you design the wall using the provided design tool, you'll find that the Robot took the same internal forces.
However, when you check the results for the core wall, you'll find higher internal forces (more than 6 times the average for one wall).
My questions are :
- Is it necessary to change the structural wall to core wall ?
- what's the difference in results between core wall and normal shear wall?
The following pictures show the model and the results
Core wall Max. Fz Axial load.PNGCore wall Max. Mx.PNGCore wall Max. My.PNGCore wall Max. Shear load Fy.PNGIntrnal forces used to design wall by robot.PNGPanel No. 625.PNGResults for core walls.PNG
1 REPLY 1
Artur.Kosakowski
You may think about a core wall being a cantilever bar element with displayed bending moment diagram which is based on the values obtained for each of the panels defining the core wall.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
