'Copy load' API issue
NNBL
NNBL
I am using this API to copy load from one load case to another. This API I downloaded from Autodesk website long back and it was working fine.  Couple of days back I updated my PC window from 10 to 11, then onwards this API is creating a problem. Which ever load case I copy, it gets deleted from load combinations. I am not sure it is because window change on not,  anyone knows what could be possible reason for it?
Romanich
Hi @NNBL ,
I think you are using the first version of this great plugin. Try to download v.2:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addin-for-coping-loads-for-load-c...
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
NNBL
I tried with Version 2 of it. Still the same problem, it is deleting the copied load case from the load combination.
Stephane.kapetanovic
hi @NNBL
the program in its v2 version dates from 2014, try to contact Igor Saltykov @Anonymous in private message or on his Linkedin page, so that he recompiles.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
