04:52 AM
Hello There
I would appriciate if someone could explain to me what exactly the L represents in a coordinate on the steel design output calculations.
I have this structure
However beams have different L values in the cordinate even if they are the same lengths and the deflection limits are calculated correctly.
I would expect the L to represtn the total length of the beam and in one of the two examples this is the case.
Is this L refered to the actual lenth of the beam or is something different?
Thank you in advance
