Hello community!
I have built up a working RSA model according to Eurocode in metric units. I now want to translate this into the American standard and verify it according to TIA-222 rev G, altough keeping it in metric.
My model consists of a steel tower with a wind load aquired from a wind simulation from RSA on a surrounding cladding. I've managed under both preferences and job preferences to change to US and also changed back all the units from im
I have also tried to change my model to the american design codes, but I had troubles figuring out which of the design codes is the correct one for me. See attached code list. I can't find TIA in the list, but a quick google gave me a relation between TIA and EIA, can anyone confirm that this is the correct design code?
I then continued to look at the combination of loads, I was hoping to use some kind of automatic combination, but once again I'm met by several options, see attached load combination list. If you could help me determine which of these (or perhaps an other) is best suited for me.
At the moment, I'm only intrested in aquiring the forces/reactions, so i belive that if I can just get this working, the rest will follow rather smoothly, hopefully.
Sorry for my english.
Regards, Thyman
