Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Convert Etabs to ROBOT
3 REPLIES 3
ducvanvt
3889 Views, 3 Replies
I am trying to convert Etabs file to Robot and have encountered some problems. Before getting into that, this is my converting procedure:
1> Remove meshing for slabs and shell in Etabs
2> Save Etabs file as *.s2k
3> Define material names so that materials in Robot match with ones in Etabs
4> Open *.s2k file in Robot which produces the corresponding *.str file.
5> Go to *.str file and manually put in some special sections (e.g tapered I beams) that Robot was unable to convert from Etabs file.
6> Check and manually put some missing loads in the *.str file.
7> Slabs were not imported from *.s2k file
My questions/problems are:
1> How to import special sections (tapered I beam for example ) from Etabs to Robot
2> Why some loads are missing ? If you looks at the *.s2k file and the original *.str, for load case 5 (W1) some loads at the top members (member number 1,2,3,...9,10..etc) are not converted to *.str. They have to be manually put in (see modified *.str file). How can we import them all ?
3> I have to draw the missing slabs and their associated loads manually in Robot. How to avoid this ?
4> The results between the two software packages are somewhat different by 1% to 7%. I checked the sum reactions are the same in both models, checked all the support conditions, released members etc.
Please note I have only double check load inputs for load case 5 (named W1).
Could someone please help ?
Thanks !
3 REPLIES 3
Artur.Kosakowski
in reply to: ducvanvt
The converter doesn't cover all ETABS functionalities and the data which have not been transferred need to be manually entered in Robot.
Artur Kosakowski
ducvanvt
in reply to: Artur.Kosakowski
Thanks for your quick response.
But why assigning loads Robot excludes some members ?
Artur.Kosakowski
Most likely the converter was not able to correctly translate the corresponding part of load definition from ETABS to Robot.
Artur Kosakowski
