I'm learning to use Robot and need some help here.
I started a simple structure in 2D frame and after I finished modelling, I realised I should have used 3D frame. Is it possible to convert a 2D frame to a 3D frame file?
Is it true that I cannot put in loads in the 'y' direction in a 2D (with X-Z coordinates) frame model?
Solved by napooil. Go to Solution.
