Connection of Steel beam to shear wall
rameez.iqbal
1,990件の閲覧回数
5件の返信
メッセージ1/6
rameez.iqbal
I have modeled a steel building in Robot where steel beams are connected to shear walls. The shear forces from the shear walls are being transferred to the steel beams, which I do not expect to be.
The issue is arising from beams 44, 193 and 105. I am attaching the model for your review.
Thank You,
Rameez.
0 件のいいね
解決済み
1,991件の閲覧回数
5件の返信
返信 (5)
メッセージ2/6
rameez.iqbal
Attaching screen shots as well.
0 件のいいね
メッセージ3/6
Rafal.Gaweda
Autodesk Support
Autodesk Support
解決済み
Are you referring to such peak values caused by model inaccuracies?
Rafal Gaweda
0 件のいいね
メッセージ4/6
rameez.iqbal
Yes...I think that was the problem here... Thanks for your reply.
Another issue in the model is that there is Type 3 Instability warning...and it seem to change the node every time I re run the analysis... In some of the discussions in your forum I had seen that this type 3 warning can be ignored.. Can I ignore it in my model as I have thoroughly checked as to why this warning is occurring but could not come up with the answer.
Thanks again for your response.
0 件のいいね
メッセージ5/6
Rafal.Gaweda
Autodesk Support
Autodesk Support
解決済み
In this case in this model it is mathematical instability - ignore it
Rafal Gaweda
0 件のいいね
メッセージ6/6
rameez.iqbal
Thank You.
0 件のいいね
