Concrete structural columns calculation options
joao.martinsPXQ9Q
joao.martinsPXQ9Q
How can I force "nominal curvature" to be the default second order analysis method?
Even if I save as with that option selected when I apply it to a certain column it doesn't make a difference. I have to manually override that option one by one even if I have hundreds of columns
Thank you.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @joao.martinsPXQ9Q
You can select several columns in Project Browser and then also in Project Browser you can assign saved set of parameters for all of them.
Krzysztof Wasik
joao.martinsPXQ9Q
Hello  Krzysztof_Wasik. Thank you for the reply.
It’s like I said in my post. Even if I save a set of calculation options template with the check box selection on nominal curvature and assign that set to my structural columns, when I run the calculations it changes back to nominal stiffness and I have no manually override one by one that check box, regardless of what is defined in the calculation option template. Help needed.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
It seems to be issue in program while RC column calculation parameters saving. I am registering this issue in developers database
Krzysztof Wasik
