why do not consider QPR combination while accepting load combination in RC module?
Solved by Artur.Kosakowski. Go to Solution.
Could you attach the rtd file and indicate which beam to look at please?
plz read the problem i wrote.
the support width is another problem from what i ask.
Cancel that beam and recreate a new beam. It will not find QPR combination (n°12 and 13)
I can't see any issue with import of QPR combinations:
Try to install SP5 for RSA 2012
