Compression only panel linear release
Larry_Wong93D45
Larry_Wong93D45
Community Visitor
Community Visitor
I'm modelling a segmental shaft by modelling each ring as a panel (shell element). Since panel to panel interface should only transfer compression, I applied linear release on the edges with released direction (Ux, Uy+, Uz and Rx), only left Uy- unchecked. I modelled bar elements to connect the rings and hoping tension can be transferred through the bar.  However, the result still showing tension is being transferred through the panel. If anyone please let me know what's the right way to model linear release between the panels in which they are only allowed compression transfer?
Thanks in advance.
Simau
@Larry_Wong93D45
Create a little gap (as small as possible) between rings and join adjacent finite elements with dummy bars;
add also dummy bars around rings perimeter to avois instabilities
Apply unidirectional release to vertical dummy bars
M. Agayr
