Composite Beam
Composite Beam
Michele100100
Composite Beam
Michele100100
I did a composite beam (steel/concrete) doing section from section definition in RSA.
Now I don't need any reinforcement, but I would like only to know the Plastic Moment of the section, to compare with the only steel section. Could I use Steel section design tool to do that? what i need, It is something like steel section Moment + Concrete section Moment partialized with the neutral factor n.
For example, if you have a steel beam with on top a concrete slab, you can find Plastic moment of the whole section after calculated the neutral axes.
Romanich
Hi @Michele100100 ,
You can get plastic moment from the Section Definiton:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Michele100100
thanks, but is that of the concrete section, steel or both together?
Michele100100
The Plastic Moment that Im looking for is the Resistance Moment of the composite section: for example if was only a steel S275 section IPE180, Mrd = Fyd/1.05 x Wpl,y  = 275MPa/1.05 x 166414.93mm3 = 43.58 KN*m.
In composite section, the Wpl,y you shown is both sections together? some like weighted values?
Many Thanks again.
Romanich
Marked with * - weighted values
https://help.autodesk.com/view/RSAPRO/2023/ENU/?guid=GUID-3C08787E-34CE-4FB0-B0B0-DFDC50EA9E8E
Roman Zhelezniak
Michele100100
thanks
Michele100100
Sorry, one more things:
What does it means Base Material in the first window? Because if I choose steel I have at the end a Wpl,y* value, if I choose concrete, I have a different  Wpl,y* value.
